I have a simple code below trying to iterate through all the assembly component and copy the iProperties > Occurrece Name (i.e. "Part1:1") and paste it to iProperties > Project tab > Part Number field for each individual part in assembly.
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
Dim oName As String
oName = oOccurrence.Name
iProperties.Value(oOccurrence.Name, "Project", "Part Number") = oName
MessageBox.Show(oOccurrence.Name, "iLogic")
Next
The Debug message shows the correct output for every iteration, but when I check each part's properties they all have the Occurrence Name of the last part in the aseembly.
I am obivously doing something wrong with the code, but I can't get my head around it at the moment and was hoping someone could help me.
Many thanks,
Vas
Hi vampelas,
I took just a moment to test the code as written and it seemed to work as expected. I can't offer much of a guess as to why you were seeing different results, but you might try testing it on a new simple assembly to see if it works.
I hope this helps.
Curtis
Hi Curtis,
Thank you for prompt resonse!
The assembly I am actually trying this is a basic assy template with multiple instaces \ occurrences of the same .ipt file... Maybe that's where the problem is, not sure .
It seems to iterate through the part occurrences properly, but eveytime it copies the iproperty value, it copies it to all the occurrence at once for however many times it iterates.
I hope this makes some sense...
Best Regards,
Vas
I think I've answered my own question there, because even in the assembly environment, when I try and change an iProperty of one of the part occurrences (i.e.. Part1:4), that iProperty value gets copied to all the Part occurrences in the assembly. Unless there is a particular code that will give me access to just one of the occurrence properties then I don't think this is possible.
I also failed to explain my initial issue properly the first time. My initial reason behind this code comes a customer support request... The customer has a lot of DWG drawings with views of an assembly, and within that assembly there are multiple instances of Parts (i.e.. Part1:1, Part1:2, ... , Part7).
The customer is then using the Auto-Balloon command to annotate those parts, with "Ignore Multiple Instances" option activated. And wants the Balloon text to show the Part name as shown in the Model Browser ((i.e.. Part1:1) to indicate the Occurrence number after the name.
My initial thought was trying the Inventor Style Manager > Dimensions > ISO Balloons and see which properties from the drawing and model can be tagged on the balloons.
This didn't really help, one because there was no property available that would accommodate that, and moreover because the way I see it, the Balloons take information from the Drawing file and the BOM table of the model, and not from the Model directly.
And also when you Auto-Balloon, by box selecting all parts in the view, the placement of Balloons does not start with Part1:1 for example, which makes it difficult to relate to the assembly information though vba or iLogic code.
In any case, I have developed the VBA code below so the user can add and add and run this through his ribbon button. With a major disadvantage to the code, in that when the user performs an Auto-balloon annotation command and is about to select the Components, he needs to hold Ctrl button and select every part occurrence from the Model Browser individually and in a Decremental order (i.e..: Part1:7, Part1:6, ... , Part1:1) in order for the appropriate balloon text values to be overridden with the Occurrence names for the appropriate part.
I hope this makes some sense... I haven't got much experience with VBA code to be honest, but I enjoy playing around with Inventor API, and was hoping someone could check through this case and give some advise. Many thanks in advanced!
Sub UpdateBalloons()
' Set a reference to the Drawing Document.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the the Full File Name of the Drawing.
Dim oFullFileName As String
oFullFileName = oDrawDoc.FullFileName
' Set a reference to the Full File name of the drawing,
' remove ".dwg" from name, and add ".iam" extension.
Dim oAsmName As String
oAsmName = Left(oFullFileName, Len(oFullFileName) - 4) & ".iam"
' Set Reference to the Assembly and Open Silently
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.Documents.Open(oAsmName, False)
' Set a reference to the assembly component definintion.
Set oAsmCompDef = oAsmDoc.ComponentDefinition
' Set reference to Balloon Counter
Dim BalloonCount As Long
' Set Ballon Counter to 1
BalloonCount = 1
' Iterate through all of the Part Occurrences
' Set Reference to Occurrence Name
Dim oOccName As String
oOccName = oOccurrence.Name
' Set Reference to Part Document
Dim invPart As Document
Set invPart = oOccurrence.Definition.Document
' Set Reference to Part's iProperies
Dim oPropertySet As PropertySet
Set oPropertySet = invPart.PropertySets.Item("Design Tracking Properties")
' Set Reference to Part's iProperty "Part Number"
Dim oPartNumber As Property
Set oPartNumber = oPropertySet.Item("Part Number")
' Set Value of "Part Number" iProperty to Occurrence Name
oPartNumber.Value = oOccName
' Set Reference to Active Sheet
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Set Reference to Ballon in sheet
Dim oBalloon As Balloon
Set oBalloon = oSheet.Balloons.Item(BalloonCount)
' Set Balloon stype to Hexagon
oBalloon.SetBalloonType (kHexagonBalloonType)
' Set Reference to Ballon Set within Sheet
Dim oBalloonValueSet As BalloonValueSet
' Iterate through all the balloons in sheet
For Each oBalloonValueSet In oBalloon.BalloonValueSets
' Override Balloon text with Occurrence Name
oBalloonValueSet.OverrideValue = oOccName
Next
' Increase Balloon Counter by 1 within For loop
BalloonCount = BalloonCount + 1
Next
oAsmDoc.Close (True)
End Sub
Best Regards,
Vas
Is there anyway to make this code loop through sub assemblies?
thanks
john
Stumbled across this old post while researching a solution...so here's a bit of code.
' http://inventbetter.blogspot.com Option Explicit Sub Main Dim oAsmDoc as document oAsmDoc = ThisApplication.ActiveDocument ' Are we in a Assembly Document? If oAsmDoc.DocumentType <> kAssemblyDocumentObject Then Exit Sub End If ' Call the Function which does the recursion Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences,1) End Sub Private Sub TraverseAssembly( Occurrences as ComponentOccurrences, Level as Integer)
' Iterate through all of the occurrences in this assembly. Level 1 components Dim oOcc as ComponentOccurrence Dim oDoc as Document Dim custPropSet As PropertySet
For Each oOcc in Occurrences
If (InStr(oOcc.Name, "Bolted") + InStr(oOcc.Name, "BC")) = 0 Then ' Get the selected item document occurrence name Try oDoc = oOcc.Definition.Document custPropSet = oDoc.PropertySets.Item("Inventor User Defined Properties") Dim oBrowserNode As String oBrowserNode = oOcc.Name
Try custPropSet.item("BOM_level").Value = Level Catch custPropSet.Add("", "BOM_level") custPropSet.item("BOM_level").Value = Level End Try If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call traverseAssembly(oOcc.SubOccurrences, Level + 1) End If Catch ' Nothing End Try
End If
Next End Sub
Some iLogic created to push a assembly level down through the assembly using recursion.
We are ignoring bolted connections.
Derived from several sources, main source - http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
