Hey everyone,
Does anyone know if there is a class or someplace where I am able to go and learn the vb.net programming language thats geared towards inventor?
not the right place, check the 4th (at the moment) permanent topic in this forum to get started.
Don't be afraid just play with it, you can't really break anything, a bit hard to start if you've never programmed before, but it you have I'll shut up.
A very easy way to get started on programing is VBA through something like excel, record a macro and see what it spits out, and try understand it, just remember is spits out alot of superfluous crap that you didn't really do or need. Once you understand a little of the syntax Inventor is just about the same but with different objects, which you'll find when you look at that topic.
http://usa.autodesk.com/adsk/servlet/index?id=1079044&siteID=123112
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=17324828
Start From Basics
For Ex:
First add code to Reference the document via APi
then select a plane on to which Sketch has to be executed via APi
Draw a circle, Rectangle
then adding constraints to the circle midpoint and origin of a sketch
then dimensioning it
exit sketch
select profile
then extrude
Yeah I have programmed before and have been playing with it. I know that the best way that I learn is from examples coupled with explanations. What I seem to find a lot of is examples with no explanations, where I work now there really isn't time to play and discover all the intricate details of the code and then determine the supurfluous code from the real code.
I have gone through that walkthrough, however I found it not as comprehensive as I would have liked. (I probably sound greedy)
Speaking of which, what's the difference in writing the code into the visual studio express environment and a .txt file that inventor sees as an external rule?
Thanks for the response!
