Inventor General Discussion
Active Member
rjones0215
Message 1 of 28 (1,501 Views)
ilogic and work plane visibility
1501 Views, 27 Replies
03-23-2012 10:59 AM
Is there a way to turn off visibility on work planes using ilogic?   Also, is there a way to change an extrusion type from an assymetrical extrusion to a one direction extrusion using ilogic?
Inventor 2013 Certified Professional
This will turn the visibility of Work Plane1 off
Dim
oDoc As PartDocument
oDoc
= ThisDoc.Document
For Each
oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
If oWorkPlane.Name = "Work Plane1" Then
oWorkPlane.Visible = False
End If
Next
Hi Diswill,
I think this will do it. I didn't have much time to review this, so you might find some un-needed lines, etc.
I'm probably missing something obvious, but as is this example only looks at sub assemblies one level deep. Meaning that if you have an assembly in your subassembly, it won't turn off the workplanes for the same reasons as before (view reps).
If I think of something different, I'll post back.
I hope this helps.
Curtis
sample #4
'get user input
oInput = InputRadioBox("Select workplane visibility:", _
"Turn ON workplanes for all components", "Turn OFF workplanes for all components", "False", "iLogic")
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Define the open document (top level assembly)
Dim openDoc As Document
openDoc = ThisDoc.Document
'define view rep
Dim oViewRep As DesignViewRepresentation
Dim sVRep as String
'change to something else if Default is used for something already
sVRep = "Default"
'create or activate view rep in the top level assembly
Try
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
'create new View Rep
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
'create or activate view rep in subassemblies
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
Dim subDoc As AssemblyComponentDefinition
If docFile.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
subDoc = docFile.ComponentDefinition
Try
subDoc.RepresentationsManager.DesignViewRepresentations.Item(sVRep).Activate
Catch
subDoc.RepresentationsManager.DesignViewRepresentations.Add(sVRep)
End Try
Else
End If
Next
'toggle work planes in the open document (top level assembly)
For Each oWorkPlane In openDoc.ComponentDefinition.WorkPlanes
'toggle all work planes
If oInput = True Then
oWorkPlane.Visible = True
ElseIf oInput = False Then
End If
Next
'look at only the subassemblies
Dim subDocFile As Document
For each oCompOcc in oAsmCompDef.Occurrences
If oCompOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oCompOcc.SetDesignViewRepresentation(sVRep,, True) 'True sets the view rep to be associative
Else
End If
Next
'Look at all of the files referenced in the open document
'format file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
For Each oWorkPlane In docFile.ComponentDefinition.WorkPlanes
End If
Next
Next
iLogicVb.UpdateWhenDone = True
Hi  pistonrod8,
Here is a modified version that handles all work features.
I hope this helps.
Curtis
'get user input
oInput = InputRadioBox("Select work feature visibility:", _
 "Turn ON work features for all components", _
 "Turn OFF work features for all components", "False", "iLogic")
'define view rep
Dim sVRep as String
sVRep = "Default"
Try
Catch
End Try
Try
Catch
End Try
Else
End If
Next
    'toggle work features in the open document (top level assembly)
    End If
    Next
    For Each oWorkAxis In openDoc.ComponentDefinition.WorkAxes
    oWorkAxis.Visible = True
    oWorkAxis.Visible = False
    End If
    Next
    For Each oWorkPoint In openDoc.ComponentDefinition.WorkPoints
    oWorkPoint.Visible = True
    oWorkPoint.Visible = False
    End If
    Next
Else
End If
Next
    'toggle work features in the components
    End If
    Next
    For Each oWorkAxis In docFile.ComponentDefinition.WorkAxes
    End If
    Next
    For Each oWorkPoint In docFile.ComponentDefinition.WorkPoints
    End If
    Next
Next
Distinguished Mentor
swordmaster
Message 2 of 28 (1,496 Views)
Re: ilogic and work plane visibility
03-23-2012 11:44 AM in reply to: rjones0215
Dim
oDoc
= ThisDoc.Document
For Each
End If
Next
Inventor 2010 Certified Professional
Curtis_Waguespack
Message 3 of 28 (1,481 Views)
03-23-2012 01:23 PM in reply to: rjones0215
Hi rjones0215,
Here's another rule that toggles all of the workplanes on/off.
I hope this helps.
Curtis
'define document
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
'look at the workplane collection
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
If oWorkPlane.Visible = True Then
ElseIf oWorkPlane.Visible = False Then
End If
Next
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
swordmaster
Message 4 of 28 (1,476 Views)
03-23-2012 01:51 PM in reply to: Curtis_Waguespack
Nice rule Curtis
Active Member
rjones0215
Message 5 of 28 (1,457 Views)
03-26-2012 05:17 AM in reply to: rjones0215
thank you.  These definitely help.
Active Member
david.campbell
Message 6 of 28 (1,350 Views)
09-24-2012 09:43 AM in reply to: Curtis_Waguespack
How can I make this work so that from an assembly plane visibility is changed to false in all sub assemblies and and parts.
Inventor 2013
Curtis_Waguespack
Message 7 of 28 (1,338 Views)
09-24-2012 10:35 AM in reply to: david.campbell
Hi Diswill,
Here are 2 quick rules that should give you an idea of how to do this. I didn't take a lot of time to test this, so be warned that you might bump into issues with locked design view reps, etc. But this should get you pointed in the right direction I think.
I hope this helps.
Curtis
sample rule #1
'get user input
 "Turn ON workplanes for all components", "Turn OFF workplanes for all components", "True", "iLogic")
'format  file name
End If
Next
Next
sample rule #2
'toggle work planes on, if off & off if on
'format  file name
End If
Next
Next
Active Member
david.campbell
Message 8 of 28 (1,324 Views)
09-24-2012 11:01 AM in reply to: Curtis_Waguespack
working with your sample 1
user defined planes are not switching.
if I make a offset plane from orgin plane xy when I run sample 1 the plane I created is unaffected by this rule.
Inventor 2013
Curtis_Waguespack
Message 9 of 28 (1,317 Views)
09-24-2012 11:25 AM in reply to: david.campbell
Hi Diswill,
Sample#1 should have worked for your original request  "plane visibility is changed to false in all sub assemblies and and parts.", but if you have user workplanes at the top level assembly as well, then you might need to add a few lines to look at the workplane collection in the top level assembly,  as in example #3 below.
Again the issue could be with locked design view representations as well. It's difficult to guess without more details, but hopefully this example will help you work it out.
I hope this helps.
Curtis
 sample rule #3
'get user input
End If
Next
'format  file name
End If
Next
Next
Active Member
david.campbell
Message 10 of 28 (1,308 Views)
09-24-2012 12:04 PM in reply to: Curtis_Waguespack
Please let me claifiry
 the current code I have is
'get user input
oInput=InputRadioBox("Select workplane visibility:", _
'catches planes in current assembly
IfoInput=FalseThen
'define document
DimoDocAsAssemblyDocumentoDoc=ThisDoc.Document
For EachoWorkPlaneInoDoc.ComponentDefinition.WorkPlanes
'toggle all work planes off
IfoWorkPlane.Visible=TrueThenoWorkPlane.Visible=False
End If
Next
ElseIfoinput=TrueThen
'define document
'toggle all work planes on
IfoWorkPlane.Visible=FalseThenoWorkPlane.Visible=True
End If
Next
End If
'catches some planes in subassemblies
DimopenDocAsAssemblyDocumentopenDoc=ThisDoc.Document
DimdocFileAsDocumentForEachdocFileInopenDoc.AllReferencedDocuments
'format file name
DimFNamePosAsLong
FNamePos=InStrRev(docFile.FullFileName, "\", -1)
DimdocFNameAsString
docFName=Right(docFile.FullFileName, Len(docFile.FullFileName)-FNamePos)For EachoWorkPlaneIndocFile.ComponentDefinition.WorkPlanes
IfoInput=TrueThenoWorkPlane.Visible=True
ElseIfoInput=FalseThen
End If
Next
Next
iLogicVb.UpdateWhenDone=True
However when I open Assembly 2 the plane appears to be toggling correctly. It just appears not to reflect correctly up to assembly1.
How do I fix?
Thanks in Advance
Inventor 2013
