Inventor General Discussion
threedeenut
Message 1 of 2 (127 Views)
iLogic and Driven Constraints
127 Views, 1 Replies
04-09-2012 11:49 AM
Hey All,
I am having a problem.  I am trying to use a driven rotation to tell a part (using iLgoic) what the ammount of an offset should be. Everything works exactly as it should.  If the rotation is set to 360 deg then the diameter of the cylinder increases properly.  Unfortunately when I hit play on the driven constraint, it plays, rotates and does everything it should be the iLogic seems to be completely forgotten.  WHen I hit stop then cancel, the diameter pops to the correct size.  I ned this to update as it plays but that seems not to happen.  Any help?
Product Support
pierre.masson
Message 2 of 2 (98 Views)
Re: iLogic and Driven Constraints
04-17-2012 12:45 AM in reply to: threedeenut
Hello Threedeenut
I'm afraid it's a limitation of Ilogic (or of drive contraint). Ilogic is not computed during the drive constraint operation.
Maybe you can workaround this trying to drive the constraint directly via Ilogic, like :
Modify constraint
System.Threading.Thread.CurrentThread.Sleep(xxxx)
Recompute other value
And so on..... Adjust your sleep value. You can probably create an Ilogic form where you set the Initial and End constraint value, and the sleep time.
Hope this helps.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
