Inventor General Discussion
Active Member
0 Kudos
Post 1 of 17
ilogic - Adding User Parameters with Custom Properties Format
2533 Views, 16 Replies
05-21-2012 04:59 AM
I would like to have a rule that will add specific user parameters to a part file.  These parameters need to be formatted so the width, depth and thickness will control the description of the part.
IE:
Width=4
Depth=2
Thickness=3/16
DESCRIPTION = TS <Width>X<Depth>X<Thickness>
I would like to format each parameter so that the:
Format=Fractional
Precision=1/16
Unit string=False
This is what I have so far:
 oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByExpression("Width", "TOP_RAIL_WIDTH", UnitsTypeEnum.kInchLengthUnits)
oParameter.ExposedAsProperty=True
oParameter.Units="in"
oParameter=oMyParameter.AddByExpression("Depth", "TOP_RAIL_DEPTH", UnitsTypeEnum.kInchLengthUnits)
oParameter=oMyParameter.AddByExpression("Thickness", "TOP_RAIL_THICKNESS", UnitsTypeEnum.kInchLengthUnits)
The TOP_RAIL parameters are from a linked file.
Brian
Hi brian
Here is some iLogic code and an example file that will format parameters and add them to the Description iProperty.
I hope this helps.
Curtis
Dim oWidth, oDepth, oThickness As Parameter
Dim oFormat As CustomPropertyFormat
oWidth = Parameter.Param("Width")
oWidth.ExposedAsProperty = True
oFormat=oWidth.CustomPropertyFormat
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
oFormat.Units="in"
oFormat.ShowUnitsString=False
oDepth = Parameter.Param("Depth")
oDepth.ExposedAsProperty = True
oFormat=oDepth.CustomPropertyFormat
oFormat.Units="in"
oThickness = Parameter.Param("Thickness")
oThickness.ExposedAsProperty = True
oFormat=oThickness.CustomPropertyFormat
oFormat.Units="in"
iProperties.Value("Project", "Description") = "= TS <Width> x <Depth> x <Thickness>"
*Pro
404 Kudos
Post 2 of 17
Re: ilogic - Adding User Parameters with Custom Properties Format
05-21-2012 06:26 AM in reply to: brian
just put a check in the export box in the parameters. for the format after you put a check mark in the export box if you go over to the equation right click you wil have new options. One is custom property format in there you can change the output.....
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Pro
404 Kudos
Post 3 of 17
05-21-2012 06:27 AM in reply to: jletcher
Oh and you don't really need ilogic..
James Letcher
1,706 Kudos
Post 4 of 17
05-21-2012 08:20 AM in reply to: brian
Hi brian
I hope this helps.
Curtis
oFormat.Units="in"
oFormat.Units="in"
oFormat.Units="in"
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
0 Kudos
Post 5 of 17
05-21-2012 08:44 AM in reply to: Curtis_Waguespack
Curtis,
It works great.
Brian
1,706 Kudos
Post 6 of 17
05-21-2012 09:20 AM in reply to: brian
Hi brian,
I'm glad to hear that worked.
I noticed that I left those first two lines of the code in. They're not really needed, and don't really do anything as written because  those things get defined later in the code. They were just vestiges of my first attempt that I forgot to remove once I went a different way.  I just thought I'd mention it in case it confuses someone who happens upon this in the future.
I hope this helps.
Curtis
so, this works just as well:
oFormat.Units="in"
oFormat.Units="in"
oFormat.Units="in"
Member
0 Kudos
Post 7 of 17
12-05-2012 09:13 AM in reply to: brian
sir can anyone help me to update the thickness of a sheet metal,  through custom properties in BOM(Assembly level)
if i create opposite hand of a part the thickness will not getting updated please help me out update through custom properties, i want like if i update the custom properties thickness then automatically it has to get updated in parameters.
thanks and regards
Manjunatha
Active Member
0 Kudos
Post 8 of 17
12-20-2012 11:20 PM in reply to: Curtis_Waguespack
sir, can you help me create co to remove All Custom property?
i want to clearup all custom properties and add new one.
Thanks and regard
Member
0 Kudos
Post 9 of 17
01-15-2013 06:07 PM in reply to: akhidrosyidi
Remove directly from iproperties.
Active Member
0 Kudos
Post 10 of 17
01-19-2013 05:27 PM in reply to: manjunathmvbhat
Create the opposite hand using derived component. Derive a mirror part and bring the parameters of the original. This way both thicknesses will get updated.
