Inventor General Discussion
Valued Contributor
SteveX82
Message 1 of 5 (1,128 Views)
iLogic access to Filename iProperty
1128 Views, 4 Replies
10-13-2011 10:23 AM
I am trying to use the iProperties.Value("part1", "Summary", "iProperty") function to get the filename or complete filepath of a component within a subassembly. I know that these iProperties exist because I can insert them onto a drawing, and I see them in the general tab of the iProperty window.
However, when I try something like:
filename = iProperties.Value("part1", "General", "Filename")
I get an error message indicating that the General tab can't be found. How might I go about getting this filename iProperty, or is there an easier way?
This will get you the file path name of an component.
Component.InventorComponent("TestName").Definition.Document.FullFileName
 I'm sure there's probably a shorter way too.
Curtis_Waguespack
Message 2 of 5 (1,118 Views)
Re: iLogic access to Filename iProperty
10-13-2011 11:24 AM in reply to: SteveX82
Hi SteveX82,
I did a lot of this in this example:
http://inventortrenches.blogspot.com/2011/08/copy-design-and-revision-rolling-with.html
I think you should be able to glean what you need from there.
Also, you might find more information on customization and ilogic over here as well:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Contributor
SteveX82
Message 3 of 5 (1,092 Views)
10-14-2011 04:58 AM in reply to: Curtis_Waguespack
Thanks, Curtis! I'm not very good with API, so I think you may over overestimated my gleaning abilities.... :smileyvery-happy:
I've stumbled across a couple of examples of code (including your's) that retrieve component filenames, but they all seem to loop through all components in an assembly to do so. Is there a way to use something like the "FullFileName" code, but attach it to a single, specific component in the browser instead?
I've stabilized all of my browser names, and all I want to do is have a single line of code similar to:
filename = Component.InventorComponent("block1").FullFileName
I can see the component filename is a half-dozen locations, but does iLogic lack a simple way to capture that filename and throw it into a string parameter?
Valued Mentor
rjay75
Message 4 of 5 (1,088 Views)
10-14-2011 05:53 AM in reply to: SteveX82
Valued Contributor
SteveX82
Message 5 of 5 (1,084 Views)
10-14-2011 06:12 AM in reply to: rjay75
That's exactly what I was looking for. I figured I was just missing a few words from my code, but I had no clue what to add.
Thanks again to both of you!
