Inventor Forum
illustrator export - inventor import
12 REPLIES 12
Message 1 of 13
PetraM
8993 Views, 12 Replies
Is it possible to import curves from illustrator or any other similar program as curves in inventor?
I want to emboss a logo of a company. I've got it as outlines in illustrator.
I really don't want to import a .bmp file into a sketch and draw over it.
Thank you for your help,
Petra
12 REPLIES 12
Message 2 of 13
in reply to: PetraM
Will Illustrator export a DXF or DWG? If so, you could import vector geometry. PetraM wrote: >Is it possible to import curves from illustrator or any other similar program as curves in inventor? > >I want to emboss a logo of a company. I've got it as outlines in illustrator. > >I really don't want to import a .bmp file into a sketch and draw over it. > >Thank you for your help, >Petra > >
Message 3 of 13
in reply to: PetraM
I'd bet that illustrator could push out WMF which you could import into Acad then dump the DWG into a sketch in IV. QBZ "PetraM" wrote in message news:20853208.1100430855753.JavaMail.jive@jiveforum2.autodesk.com... > Is it possible to import curves from illustrator or any other similar program as curves in inventor? > > I want to emboss a logo of a company. I've got it as outlines in illustrator. > > I really don't want to import a .bmp file into a sketch and draw over it. > > Thank you for your help, > Petra
Message 4 of 13
in reply to: PetraM
cbliss wrote: > Will Illustrator export a DXF or DWG? If so, you could import vector > geometry. Illustrator does indeed export as dxf and dwg.
Message 5 of 13
PetraM
in reply to: PetraM
Illustrator indeed does export DWG and DXF files but when I import them into inventor (or by file-open or by importing them directly into a sketch) nothing happens. It imports it but the sketch is blank.
No idea why that happens.
Won't work through exporting it to Acad because i don't have the program.
Petra
Message 6 of 13
in reply to: PetraM
if you've got inventor you should have autocad aswell, it comes free with it
Message 7 of 13
in reply to: PetraM
when exporting from Illustrator to dwg there is always errors in the dwg. You must open the file in ACAD and run "audit", mayby change things to layer 0 and even move things to a "sensible" origin. -- IV 9 / AIP 9 Finnur P. Frodason HP X4000 - dual Xeon 2.4 XP Pro SP 2 - 2GB mem Nvidia Quadro 4 980 "PetraM" wrote in message news:5070754.1100513906966.JavaMail.jive@jiveforum2.autodesk.com... > Illustrator indeed does export DWG and DXF files but when I import them > into inventor (or by file-open or by importing them directly into a > sketch) nothing happens. It imports it but the sketch is blank. > No idea why that happens. > > Won't work through exporting it to Acad because i don't have the program. > > Petra
Message 8 of 13
stevensf
in reply to: PetraM
Can you import to Illustrator from IV or Acad and have a file that can be edited? Is there any special things ou need to do in Acad or IV before youimport into Illustrator?
Fred
Message 9 of 13
in reply to: PetraM
I haven't worked with Adobe Illustrator un awhile, so this info might not be completely accurate. Illustrator seems to work best if the import files are postscript, which you should be able to get from either acad or iv by setting up a postscript printer that prints to a file, then import that into illustrator. Hope that helps. Bob S. "stevensf" wrote in message news:16502343.1100524299478.JavaMail.jive@jiveforum2.autodesk.com... > Can you import to Illustrator from IV or Acad and have a file that can be edited? Is there any special things ou need to do in > Acad or IV before youimport into Illustrator? > Fred
Message 10 of 13
PetraM
in reply to: PetraM
Thanks a lot!!
i managed to open a wmf file in acad and then import it into inventor and it works. (Had to install acad first 🙂
How i'm gonna get the dimensions and the position right is another story since i can't really use acad. But i'll learn.
Thank you very much again!
Petra
Message 11 of 13
in reply to: PetraM
PetraM wrote: > Thanks a lot!! > > i managed to open a wmf file in acad and then import it into inventor and it works. (Had to install acad first :) > How i'm gonna get the dimensions and the position right is another story since i can't really use acad. But i'll learn. If you're going to import it into Inventor anyway, why not position and dimension it in Inventor?
Message 12 of 13
PetraM
in reply to: PetraM
I have no idea how to position and dimension it in inventor. the logo is not in standard sketch lines but in some thinner black ones. If i try to move or change the dimensions of a single line (or edge) just that single one moves and streches the whole thing.
Is there a way to convert it into normal lines or remove constraints or group it or treat it as a whole (like text)?
Petra
Message 13 of 13
in reply to: PetraM
PetraM wrote: > I have no idea how to position and dimension it in inventor. the logo is not in standard sketch lines but in some thinner black ones. If i try to move or change the dimensions of a single line (or edge) just that single one moves and streches the whole thing. > > Is there a way to convert it into normal lines or remove constraints or group it or treat it as a whole (like text)? > > Petra If you select all the lines at once, you should be able to move it as a whole (if its not constrained). If you want it to retain its shape when grabbing at a single line or vertex, then you have to constrain it (constraints, dimensions).
