In visual studio I coded for open an instance of an Autodesk Inventor in a web application using vb.net.The code is executed correctly in local.but when I am trying to host the file in IIS and try ,then it is not working some error will showing.This problem is also get when the visual studio is open as administrator mode and run.
my code is ..
GetInventorApplicationObject()
inventorApp.Visible = True
Dim oDoc As Document
oDoc = inventorApp.Documents.Open("F:\inventor\Proof Of Con\Cube.ipt")
End Sub
public sub GetInventorApplicationObject
If inventorApp Is Nothing Then
inventorApp = CreateObject("Inventor.Application")
Else
inventorApp = GetObject("Inventor.Application")
End Sub
The Error Showing is,...
Cannot create ActiveX component.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Exception: Cannot create ActiveX component.
Source Error:
Line 335:
Line 336: If inventorApp Is Nothing Then
Line 337: inventorApp = CreateObject("Inventor.Application")
Line 338: Else
Line 339: inventorApp = GetObject("Inventor.Application")
Source File: F:\inventor\Proof Of Con\WebSite14\Default.aspx.vb Line: 337
anyone know what is the issue?
It is better to post this inquary on our Inventor customization forum. I will move it for you to this forum.
