I have received a motor *.igs file from a vendor, placed it in the assembly and when I put assembly in the drawing the motor doesn't show. Does anyone know a setting or a trick to resolve this?
The funny thing is when I place this motor by itself on a drawing everything is fine.
Thank You
Regards
William
Solved by jtylerbc. Go to Solution.
Most likely it is a surface model. By default, these do not show up in a drawing view of an assembly.
Find the part in the browser under the view, right click, and select "Include all surfaces."
You're welcome, glad I could help.
Your second method is actually what I prefer as well. When possible I usually try to repair the surface model into a solid with stitching or sculpting, so I don't have to keep turning the surface model on in drawing after drawing. Include Surfaces is a nice workaround for when you just can't get the part to stitch, or are only planning on using it once.
