Inventor Forum
IGES Import problems convert to solid part
9 REPLIES 9
Message 1 of 10
chrisw01a
2154 Views, 9 Replies
Could somebody PLEASE take a look at these two IGES parts and try to convert them to a solid.  I've tried all I can think of with no good result.
I can't get them uploaded, file is too large, what can I do?
9 REPLIES 9
Message 2 of 10
chrisw01a
in reply to: chrisw01a
These are actually .rar files.  You will have to change the extention to .rar and use WinRar to extract.
Message 3 of 10
JDMather
Why are they *.rar files?
Why can't you simply use Windows Explorer to zip the files?
The limit is much larger over here http://www.augi.com
I have no interest in downloading a 3rd party software to extract your files, but perhaps this will help you
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Message 4 of 10
chrisw01a
in reply to: JDMather
Because .rar could get small enought to upload.  I'll look at the other website.  Thanks.
Message 5 of 10
JDMather
Put a link back here to the upload on AUGI as that site doesn't get  as much traffic.
I've got to get back to other work for a while, so hopefully someone will jump in here with solution.
Back to check in a while.
Message 6 of 10
chrisw01a
Message 7 of 10
JDMather
Those look pretty easy to repair - should be able to fix each in a couple of hours using the instructions I referenced earlier (with a bit of changes accounting for the Repair Environment changes from Construction Environment).
There are some missing surfaces that need patched.
But why do you need as solids?  These look like off-the-shelf Motors.  If you aren't manufacturing - why do you need solids?
Message 8 of 10
kb8fu
"Why do you need as solids?"  Inventor won't allow me to tweak components in an .ipn that aren't solids.  This precludes using models that came in from IGES surface models in an .iam file that will go into an assembly drawing as an .ipn.
Message 9 of 10
JDMather
in reply to: kb8fu
You have replied to an ancient thread.
Are you having trouble converting your imported geomtry to solids?
If so, can you attach the file(s) here so that someone can show you how to Repair the geometry?
If they are too large to attach here, the A360 website is now a good resource.
Message 10 of 10
kb8fu
in reply to: kb8fu
It took several tries but I finally wound up with what acts like a solid and is now tweak-able in the .ipn file. This involved a combination of importing the IGES file into the "repair environment" and selecting the "stitch" check box in the import options.
The help that Inventor returned for "Imported IGES data" is pretty cryptic referring to "308 and 408 structures" which was meaningless for any of us here. I still don't have a clue what that means but muddled through importing the IGES files as solids nonetheless.  This sure beat creating solid models from the ground up for those purchased parts.
