I am using Inventor 2013. I want to save an IPT as IGES and include the 3-D sketch. That is a simple operation which was performed correctly. Whe I open the IGES file I want to be able to EDIT the 3-D sketch or our supplier would want the ability to do that.
The 3-D sketch shows up but there is no option to EDIT.
Can this be done?
Solved by WILLIAMF. Go to Solution.
Never mind. I figured it out. The option th edit is there.
