I'm trying to create a table driven sheet metal punch. Everthing goes smoothly untile I try to "Edit Using Spread Sheet." When I click the icon, Inventor acts like it is trying to do something, but nothing happens. I have Excel 2010 and INV 2012.
Solved by Curtis_Waguespack. Go to Solution.
Hi michmaju,
I'm guessing this is the issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14079866&linkID=9242018
I hope this helps.
Curtis
Thank you
Thank you
Thank you.......
