Inventor Forum
If can simulating force effect between two object ?
3 REPLIES 3
ziou2004
575 Views, 3 Replies
If Dynamic Simulation can simulating athletic effect between two object(one impact another) ? For example ,one(A) is still,the other(B) is moving, when B contact A ,what happen ? if can,how to ?
3 REPLIES 3
in reply to: ziou2004
Without knowing more about the geometry of the two objects, I would
say set up a 3D Contact joint between the two, that should work. I
have tested that once before on a similar scenario and it worked quite
well.
You just have to make sure that your other object also has a joint
with degrees of freedom allowing it to move or else it will be
stationairy and cause your first object to bounce off.
Stephan
2003 Yamaha R6
kimi no koto omoidasu hi
nante nai no wa
kimi no koto wasureta toki ga nai kara
ziou2004
Thank you .Now I have kown. Give a object appropriate mass and force,it can move.
ziou2004
But Dynamic Simulation cann't identify contact.
