Inventor Forum
IDW vs DWG, what to use?
19 REPLIES 19
Message 1 of 20
giovanni79
28986 Views, 19 Replies
Recently our company moved from SolidWorks to Autodesk Inventor (mostly because of the integration of the components of the Design Suite). Overall, the Inventor workflow is very similar to the one in SolidWorks and I find no significant difference between the two programs.
However, Autodesk Inventor offers the option to create drawings as IDW or DWG files. I would like to know why you would prefer one over the other one: everything I need to do seems to be doable in the IDW files. Are the DWG files present for compatibility with AutoCAD users only or are there other advantages? Is AutoCAD more flexible and thus it would be preferrable to do the drawings of Inventor parts in AutoCAD? What are the advantages of one format/workflow over the over one?
Thank you for your suggestions.
19 REPLIES 19
Message 2 of 20
Cadmanto
in reply to: giovanni79
Oh, the more you use it the more differences you will find.  Smiley Very Happy
The difference between .idw and .dwg is the .dwg is a more compatible format for Autocad directly out of
Inventor where as the .idw is a direct parametricly created drawing from Inventor.
Hope this makes sense to you.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 20
giovanni79
in reply to: Cadmanto
Thank for the comment. So it boils down only to compatibility with AutoCAD? Any advantage in using IDW?
Message 4 of 20
Hi giovanni79,
For the most part they are the same with some differences here and there.
  • Are the DWG files present for compatibility with AutoCAD users only or are there other advantages?
It largely depends on the needs of your company. If you have then need to hand drawings to another department that uses only AutoCAD, then there might be an advantage to using an Inventor DWG. But you could also just Save off a copy of a IDW as an AutoCAD DWG or DXF, just as you might have done with SWx.
  • Is AutoCAD more flexible and thus it would be preferrable to do the drawings of Inventor parts in AutoCAD?
No, you'll be better off to detail the drawings in Inventor.
  • What are the advantages of one format/workflow over the over one?
* Inventor DWG file size is larger for the same drawing saved as an IDW
* You can use AutoCAD block in Inventor DWGs, but not IDWs.
* more mentioned below...
Autodesk Inventor supports IDW and DWG file types for drawings. Both file types produce identical drawings. IDW files are the native Inventor format. You can open them only in Inventor or Inventor View. This file type results in smaller file sizes.
The DWG file type is native to AutoCAD®. You can open DWG files in AutoCAD, Inventor, or DWG TrueView. If you create data using Inventor in a DWG file, you can modify the data only with Inventor. If you create data using AutoCAD in a DWG file, you can modify the data only with AutoCAD. If a downstream consumer of your Inventor data needs a DWG file, consider using DWG files as the default in Inventor.
Keep in mind that if a year from now you realize that one format or the other would work better than what you're using, you can batch convert the files to other file type using the Task Scheduler.
I hope this helps.
Curtis
Message 5 of 20
Cadmanto
The advantage of an IDW is that is the parametric drawing that is created right out of Inventor when you
place views from your model.  It is the direct drawing link to the model.
The IDW to Inventor is like the .slddrw in Solidworks.
Best Regards,
Scott McFadden
Message 6 of 20
Inventor DWG's are also parametrically linked to the models.
Message 7 of 20
PaulMunford
DWG s are handy if you are using g AutoCAD and Inventor. Both AutoCAD and Inventor views can be combined in one file. Inventor doesn't have a sheet set manager - AutoCAD does. I guess IDW is better if you are purely Inventor...
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 8 of 20
in reply to: PaulMunford
We use Inventor and ACAD. We use .idw's for Inventor and .dwg files for ACAD. This shows instantly whether the drawing is a parametrically linked file to a part or assembly, or a 2D generation from ACAD just by looking at the file extension. Just something we found handy.
Message 9 of 20
DVDM
Many users would be hard pressed to spot the difference between an idw and an Inventor dwg file while editing in Inventor.
I've decided on making Inventor dwg as the standard. Yes the file is somewhat bigger in size because every view is stored as an autocad block, but the benefits outweigh that.
For example, I have a drawing of a huge assembly, thousands of parts. An engineer wants to have a look at the drawing, measure up a few things, etc.
With Inventor idw, he/she would open up that drawing in Inventor, which would then try to load the entire dataset into memory, worth 100's of MB, taking ages and potentially a whole bunch of missing file references and intimidating warnings along the way.
With Inventor dwg, he/she would open a single file worth just a few MB's in AutoCAD, which is an exact representation of the model in its last saved state, which would open very quickly, and can be navigated and measured in with ease.
Because we still have a mixed setup with top level assemblies in 2D AutoCAD, but parts/subassemblies in Inventor, up-to-date blocks of these Inventor components can be quickly inserted into the 2D AutoCAD file. These blocks can even be kept up to date with the help of Design Centre, though admittedly this is not the smoothest of workflows.
Message 10 of 20
in reply to: DVDM
Interesting that it has been mentioned at least twice that the file size is larger for DWG,  I have done  a lot of comparisons and have found consistently that DWG file size is smaller….
However I concede that will depend on the typical way in which you represent your engineering drawings, if the drawing is a plain line drawing with no colour graphics the file size is less than half typ 2.4 mb IDW to 0.9mb DWG, as soon as you add textures colours the opposite (ish) happens 2.4mb IDW to 3.8mb DWG.  Presumably the graphic information is stored as a raster image in the AutoCAD file which would make the file a lot larger than purely vector information.
-edit - on larger assemblies with sufficient vector information this scale can tip and the DWG’s will become larger, my survey was based on smaller part drawings.
I would like to hear views to back up this for or aginst of course this is just my sumamising based on the drawings I have had available.
One of the main reasons I have for using DWG’s is you can use any DWG viewer /Compatible CAD programme to view the drawings, which would mean not having to use Inventor View! Which has the odd teething trouble when installing every year.
Message 11 of 20
giovanni79
in reply to: DVDM
Thank you for the detailes answer, this is the kind of thinking I was looking for. Because our assemblies are very simple and with no more than 30-40 parts each (at a great maximum), I think I will stick with the Inventor format. As other have pointed out, it is always possible to batch convert these files later.
Message 12 of 20
rolabendan
What about emedded data in idw vs dwg files when cycled between AutoCAD and Inventor? Specifically, is data entered in iproperties within Inventor editable in AutoCAD, and is data entered in attributes within AutoCAD editable in Inventor? When an idw file is saved as an AutoCAD file, what happens to the iproperty data? One example: Data stored in a title block from an idw saved as a dwg file file isn't easily editable via a dialog box from within AutoCAD, if it is editable at all.
Message 13 of 20
can we view IDW files out of Inventor?
I have designers using inventor and exporting files to IDW and DWG, I also have tech that needs to be able to visualize the files, sometimes they try to open IDW files because there is no DWG.
Best Regards
Eugenio Sanchez
DB Administrator
Kovatera Inc
Message 14 of 20
cfairfowl
I use both, just depends on the project, the thing I like about the .dwg file is you can open the drawing in Autocad and use the excellent rev cloud feature. The rev cloud "add-in" or "after though" in .idw is a real pain in the butt and Autodesk are oblivious to why rev clouds are vital especially for after "Approved For Construction" drawing re-issue.
Message 15 of 20
b.mccarthy
Bear in mind that the dwg file size can be significantly larger. It will depend upon the complexity of the base model, as you can see from an extreme example below (there are 7 sheets):
In this case, the dwg is approx. 7.5x larger.
So, as always, caveat emptor...
Message 16 of 20
johnsonshiue
in reply to: b.mccarthy
Hi! Let me chime in a bit. Comparing the sizes of idw and dwg may not be fair. The idw files are compressed files (you may use 7zip to open the archive), while dwg files are not compressed. If you compress a dwg file, it will also become smaller.
Many thanks!
Software Test Engineer
Message 17 of 20
b.mccarthy
Wow. Learn something new every day!
Thanks, Johnson!
Message 18 of 20
cfairfowl
in reply to: cfairfowl
Absolutely spot on. That's what I do.
Message 19 of 20
MH-J
I find the dwg format to be more versatile than the idw. One advantage is the creation of mirrored views in a drawing; specifically Isometric views for reference showing an opposite hand assembly. Rather than creating a mirrored assembly that may contain 1000's of parts and creating a view based on it, it's possible to take an existing view, open the view in Autocad, mirror it, and bring it back into Inventor. The view is still parametrically linked to the original model and will update to reflect any changes but is a mirror of it. Very handy if you just need to show an opposite hand of an assembly rather than creating a whole new opposite-hand assembly file.
Mike
Message 20 of 20
johnsonshiue
Hi! Another benefit of using dwg file is to view it using DWG TrueView or AutoCAD web (as well as viewer.autodesk.com).
Many thanks!
