I am wondering if there is a way of exporting an existing IDW created in Inventor to DWF format without having to phycially open the IDW in Inventor ? I have a list of IDW's and some of them are referencing large assemblys and take a long time to open and it would be better if I could do a batch export outside the Inventor environment.
Inventor 2013 SP2 64-bit edition
Product Design Suite Ultimate 2013
64-bit HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Solved by Curtis_Waguespack. Go to Solution.
You could try the Task Scheduler, tucked away in the Tools sub-folder in your Inventor Start bar folder.
Under the Create Task menu there's the option to "Publish DWF Files..." - give that a play and see what happens (don't use DWF so I admit I'm not that familiar with it.)
Hope that helps
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Hi Anthony,
You can use the Task Scheduler to batch IDWs to DWF:
This can be done overnight if needed.
Gereral Task Scheduler info:
I hope this helps.
Curtis
This is great thanks, just what I was looking for, I'd forgotten about the task scheduler, I'll give it a go.
