HI
I'm having a problem saving IDW to AutoCAD DWG.
On the IDW there´s a couple of section views. All views are ok.
But on saving the drawing to AutoCAD DWG, one of the section shows up in both the correct size(1:10) AND in 1:1 !?!
The base scale of the drawing is 1:15 but in this paticullar section view there´s som details that has to be bigger.
Why is this happening?
And here´s something even more strange: If I delete the section view in the IDW it stil shows up in 1:1 when saving to AutoCAD DWG !!
I have tried every possible(to my knowledge) setting on the saveas-options tab, but no luck so far.
This is a recurring problem on different drawings.
See attached screenshots for clarification.
Any help is highly appreciated.
/carstn
Mine seems to export fine. Have you tried exporting to dxf just to see what happens, What AutoCAD version are you saving in?
You've been trough these settings?
Try with different drawing, different computer.
Attach the file here.
