I'm currently setting up the default templates for our office for all our different title blocks. I was hoping to be able to have 1 template for both standard and metric dimensioning. When the template is opened it is currently set up so you have to select the Title Block that you want to use. Is there a way to set it up so there are different drawing defaults when different Title Blocks are selected?
If I select the Metric Title Block I don’t want the dimensions to come in as standard by default. If not I’ll just have to create 2 different templates.
Inventor 2013
Thanks!
Solved by cwhetten. Go to Solution.
Inventor doesn't work this way, ordinarily. But it might be possible to write an iLogic rule that does something like this. Are you familiar with iLogic?
-cwhetten
Yes I am. Maybe I can just have a Form that lets you select the defualts you want to use. I'll have to mess around with that.
Thanks for the idea.
One way you could approach this is to set up two drawing style standards: one for 'standard' dimensions, and one for metric. Your iLogic rule could ask the user to input (through a form, if that's your preference) which title block they want, then it would activate the appropriate drawing standard.
I might be able to help you out with the code if you would like.
-cwhetten
