If it's what I'm thinking of, 5.3 has a problem with spline silhouette
projections showing as roughly faceted polyline looking curves. I don't think
there's anything you can do other than export the drawing and clean it up in
Acad, etc. It's much improved in IV6, fwiw. You might check a print to make
sure it's not something else graphics related.
"jakehandy" wrote in message
news:f14ed5b.-1@WebX.maYIadrTaRb...
I model a handle for a home appliance product. When it's time to produce the
IDW, it happenned, Top view was OK, but when I created the projected views and
section view, the arc shows almost as straight line (although it's a spline
when I click it), when I change the view using "edit view" and select "shaded"
the look was OK. But when I return it to "Hidden Edges On" mode it screwed up
again. Already try to change the Display mode in "Application Options" (Rough,
medium, smooth), even try using different setting on "Hardware" tab
(recommended setting, Full Optimization, etc.) still nothing. My machine is
Intel P 1,7GHz, Oxygen VX1, 750 MB RAM. Any help would be greatly appreciated.
It's a shame to give our supplier a LOW QUALITY drawing.
