You could output to DWF, and then in Word go to Insert>> Object >> and
select AutoCAD Express Viewer Control. You should get a box showing
on the page. Click out of the box, and then click back on it and you
will see the stretch controls. Right click and select Properties. From
there you can browse to the DWF you saved.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Allan"
wrote in message
> I need to save my idw's into a format where my client can insert them
into a
> office 2000 (word) document & be able too resize the image by dragging
the
> corners in & out etc (in word).
