Hi to all,
i have a idw with nothing inside ( i have removed every view...every drawing resource.. sheet format...style standards unnecessaries...purged...
the filesize is still high : 59 Mb !!
Moreover...when compressed (rar or zip), it 's reduces to 520 kb !!
Can someone discover and solve this mistery?
Thank you!
Here the idw (created with inv2013) and zipped:
https://dl.dropboxusercontent.com/u/63644155/WTF001.zip
Try doing a file save as copy>template. See if the new file is a smaller size.
I am thinking that something got trapped in the memory of this template file.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi Cadmanto..neither in that way.. 😞
i agree..something is in the file...i would like to know what...and how to clean it.
If that didn't clear it, then what I would try is call up the default out of the box template of comparible size, do a file save as>copy of it, call up the newly saved file then delete all of the borders and titleblocks from it. Call up the one you are having issues with and copy those titleblocks and borders and paste them into the new tempalte file.
This should get rid of what ever is embedded in the background. This making your files size smaller.
Ok, undesrtand.
I was just curious to solve that and undesrtand what was and how to clear it. But it looks like with no solution.
Only copy past in an clean idw.
Yes, a clean file is your best bet, but I would also suggest not only an .idw but make sure this is done to your template file. That way this clean file will carry through all newly created drawing files.
as long as its not your template file then just say who cares, hit delete, and move on..
