Inventor Forum
Idw files and xls insertion
3 REPLIES 3
phivert
387 Views, 3 Replies
Hello
When I insert an xls file in a drawing (idw or dwg), I do not see all the contents of the xls file.
I have the same problem with copy paste excel spreadsheet control.
The problem is the same on different. I think there is a size limit for OLE objects in Inventor .
Someone he already encounter this problem?
thanks
3 REPLIES 3
mcgyvr
in reply to: phivert
http://forums.autodesk.com/t5/Inventor-General/Missing-rows-from-inserted-Excel-object/td-p/3499014
Cadmanto
Is your excel file you are inserting an .xls or an .xlsx file?  The software will only allow you to insert an .xls file.
Is this spread sheet you are inserting one that cannot be created using a general table?
Using a general table would be the cleanest way to do this if possible.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
in reply to: Cadmanto
as in that post I linked to.. "paste special" works much better than insert object in Inventor..
