Inventor General Discussion
Active Contributor
AhmetSevik
Message 1 of 8 (419 Views)
IDW file format update to all my old idw files
419 Views, 7 Replies
02-02-2013 05:47 AM
I am user for Inventor 2013 Professional.
1 year ago i created a format for my idw template file. I set many things under Drawing Resources in browser.Sheet Formats, Borders, Title Blocs, Sketch Symbols... etc. Now we want to change something in this resources and i will create new one.
My question is if i create new one, then can i update all new formats to my old idw files? I mean, i can't open all of old files and i can't change one by one. I want to do in easy way.
Thanks.
Ahmet ŞEVİK
Have you looked at the: "Drawing Resource Transfer Wizard" that is shipped and installed with Inventor. It's located within the Inventor>Toold of the Start Menu
Active Member
gamboaj8
Message 2 of 8 (410 Views)
Re: IDW file format update to all my old idw files
02-02-2013 07:08 AM in reply to: AhmetSevik
i think there's a way to save your old files to 2013.
blair
Message 3 of 8 (402 Views)
02-02-2013 09:28 AM in reply to: AhmetSevik
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
blair
Message 4 of 8 (394 Views)
02-02-2013 10:55 AM in reply to: AhmetSevik
Here's a good link: http://blogs.rand.com/manufacturing/2011/08/all-my-inventor-drawings-need-a-different-title-block-ar...
Win7-64
Active Contributor
AhmetSevik
Message 5 of 8 (383 Views)
02-02-2013 11:05 PM in reply to: AhmetSevik
I solved my problem with Drawing Resource Transfer Wizard. I did'nt see till now this wizard under start menu.
Just one point; if your files saved with different inventor version then this wizard couldn't succes to convert. Then you should to open your old file with your inventor and you have to save again with new version. Then Wizard work.
Thank you very much to all of your helps. Thanks.
*Pro
sbixler
Message 6 of 8 (368 Views)
02-03-2013 02:16 PM in reply to: AhmetSevik
If your files need to be migrated, use the Task Scheduler, also in the Start menu.  You can set up a Migrate task for a project or folder, or select individual files.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
blair
Message 7 of 8 (364 Views)
02-03-2013 02:50 PM in reply to: AhmetSevik
If you have any custom material/appearances, migrate them first. Good documents on the Autodesk website. I follow the following procedure when migrating.
1.) Have a good copy of your data. We have all data stored to a external USB drive. This is much easier to recover than having to restore from a Back-Up.
2.) Run the Task Scheduler and migrate all IPT's first
3.) Run the Task Scheduler and migrate all IAM's next
4.) Run the Task Scheduler and migrate all IPN's third
5.) Run the Task Scheduler and migrate all IDW's last
Win7-64
*Pro
sbixler
Message 8 of 8 (341 Views)
02-04-2013 04:00 AM in reply to: blair
Blair, good point about the material/appearance migration.
As for the file migration, my experience with Task Scheduler is that it performs the migrations in the proper order, so you don't have to do it four times.
Sam B
