Inventor General Discussion
charles
Message 1 of 9 (215 Views)
idw behavior
215 Views, 8 Replies
11-27-2013 04:16 AM
Hi all,
I have an Problem with Inventor 2014, I have attached pictures for info. I created an 3D model and the proceeded to create an drawing as I was almost finished with drawing the customer decided to make a change (added Lifting hole on model and only lifting holes) when the drawing updated the whole drawing was a disaster need to create a completely new drawing.
Any assistance in fixing this problem would be greatly appreciated!
Distinguished Mentor
ccarreiras
Message 2 of 9 (214 Views)
Re: idw behavior
11-27-2013 04:20 AM in reply to: charles
Hi!
No pics, no files... no help.:smileyvery-happy:
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
charles
Message 3 of 9 (206 Views)
Re: idw behavior
11-27-2013 04:50 AM in reply to: ccarreiras
ccarreiras
Message 4 of 9 (177 Views)
Re: idw behavior
11-27-2013 06:17 AM in reply to: charles
Hi!
Your issue is to have the views on top of each other?
Or you found some errors in dimensions, etc?
All you have to do is arrange again the views position...
Regards.
CarlosC
Windows 7 64Bit
-niels-
Message 5 of 9 (172 Views)
Re: idw behavior
11-27-2013 06:23 AM in reply to: charles
Seems the updated version has a workplane (or some surface) visible and it's outer edges are making all the views shift.
Can you try turning that off and see if everything falls back in place?
Using IV2014 Pro SP2 - upd.1, Win7-64bit
Product Support
bob.holland
Message 6 of 9 (138 Views)
Re: idw behavior
11-27-2013 09:42 AM in reply to: charles
Please set your your Inventor Graphics to use Software Graphics and Compatibility Mode.
Tools tab -> Inventor Applications Options -> Hardware tab
Please try this and let us know if it makes a difference.
Thank you and Happy Thanksgiving.
Bob Holland
Valued Mentor
rhasell
Message 7 of 9 (113 Views)
Re: idw behavior
11-27-2013 03:13 PM in reply to: charles
Hi
-Niels- has it.
For future, create a design view rep in the assembly/part. That has the surfaces visibility turned off.
I find that sometimes I don't have to do anything, just create the view rep, I have found that the default view rep can become a little indecisive at times when it comes to showing/hiding surfaces. This in turn throws all the views out and creates chaos, but turn it off again, and it all pops back into place.
Naturaly, set the drawing view to the new view rep.
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
charles
Message 8 of 9 (81 Views)
Re: idw behavior
11-27-2013 10:31 PM in reply to: charles
Thanx to all for the input!
I have turned off all planes in model and there was no effect on drawing views. The planes show on drawing view but not in model space.
Any reason for that? It seems that these planes are causing my problem but how do I fix this?
Thanx again!
Valued Mentor
rhasell
Message 9 of 9 (79 Views)
Re: idw behavior
11-27-2013 10:50 PM in reply to: charles
Hi
Just double check, I am not aware of workplanes causing such disruption, they normally show up as lines, surfaces useually display such behaviour.
Did you create A design view rep, turning off the visibility of the Work planes and surfaces?
After doing that, change the drawing view to reflect the new design view rep.
If it still does not update, check to see if the "Associative" checkbox is active.
If none of the above work, then we have to look deeper into the issue.
There is the manual way of doing it.
switch off the associative option
Find the offending workplane/surface in the Model tree.
RMB switch off "visibility"
Reg
