see attached jpg. this is supposed to be like a 8' long assembly sheet. there are 4 sheets in this idw and this is the only one that appears like this. this job was migrated from 2013-2014. has anyone ever seen this?
Solved by jletcher. Go to Solution.
Do you have a 3D connexion mouse? you can use that to make it right. Not sure if there is a way to fix it unless you do.
But it is odd..
A 3d mouse has buttons on it
T- for top
L- for left
R- for Right
F- for front
If I am in a IDW I can use those to show the side of the paper as you can say. I do not know why it is not disabled when in drawing. I did it by mistake one time and freaked out. see pic below.
That was it. he must have "sausage fingered" one of the other veiw buttons.
I pressed front on the space mouse and it was fixed.
thanks
Lol,
I know your a Pro, so it's just the opposite, I wanted to correct my own ignorance. 🙂
I havn't used a 3D mouse yet, even though I got one in a box somewhere (loaned).
I should send that back to Flayer sometime.
T.S.
No you should use it they are great.. Saves so much time with it..
I had a real nice one when I did demos for Autodesk I made parts without touching the keyboard. I put it on top of the monitor before the demo freaked everyone out..
I know longer have that one it broke and I did not have $1,200 to get new one..
So I just have a $350.00 one but still nice.
Whoah, I was not aware that they were that expensive.
I have a 3D connexion mouse that someone gave me when I was at Imaginit.
I will take your advice and try it out.
T.S.
They don't make that one any longer but you have to remember it was back when they 1st came out so the price was much higher then they are now.
yeah we all have 3d connection space pilots and space pilot pro's. can't work without it anymore.
