Inventor General Discussion
Valued Contributor
Mike686
Message 1 of 19 (649 Views)
iCopy position problem
649 Views, 18 Replies
09-10-2012 02:20 PM
hi, i'm trying to make some panel using iCopy
i've see this video on youTube  http://youtu.be/uRR4xsev8SU
i've follow the technique to build my panel
in the exemple i'm posting i did'nt use the icopy with the frame generator as it shows in this video
when the layout i use to place my panel is on the xy plan it works fine but if i want to insert it on another plane the panel is all wrong or it doesnt show at all..
i want to know what i'm doing wrong or at least how to make this work...
i work in the curtain wall buisness and i want to use to icopy tool to make my glass and aluminium panel..
can someone give me a little help with that...
i'm joinning with this message a pack and go,
Product Design Suite 2013
Hi Mike,
I cannot access Youtube, but based on your model, I’d suggest another way to achieve the requirement. Please check attached dataset to get the idea. The iCopy Template is located under “.\iCopyTest\iCopy_Template”. In this case, I directly use the points in sketch, but not workpoints, which may easier to understand.
Anyway, please post any follow-up questions if you have. And here are some tips for building an iCopy Template:
  • iCopy Template is the key assembly, which contains at least an adaptive layout part. You need align origin between the layout part (remove the grounded status if exists) and the top assembly.
  • The layout part should contain an adaptive sketch, and other features/work geometries/sketches are based on this adaptive sketch. During creating the adaptive sketch, you need consider which geometries will be driven by adaptive, and add necessary constraints and dimension. Note: Do not add driving dimension if the dimension may change by adaptive.
  • You can carry out parameters into iCopy definition for better controls of flexibility.
Employee
NicolasXu
Message 2 of 19 (632 Views)
Re: iCopy position problem
09-11-2012 03:15 AM in reply to: Mike686
Hi Mike686,
I took a quick look for the test dataset. One of the possible cause is that the base sketch is created on XY plane, so it will always be landing on XY plane in other iCopy instances. That means the sketch will turn to a line if inserting iCopy on YZ plane.
You may try create a work plane through the 3 work points, and then create the Sketch on the workplane.
Not sure if you have went through the tutorials, but it's worth to take a look:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0490-Use_iCop4...
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0481-iCopy%3a_...
Nicolas
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
gboshko
Message 3 of 19 (566 Views)
10-18-2012 05:37 AM in reply to: NicolasXu
HI MIKE,
I'M HAVING THE SAME PROBLEM. WERE YOU ABLE TO RESOLVE?
GEORGE
Valued Contributor
Mike686
Message 4 of 19 (544 Views)
10-22-2012 05:03 PM in reply to: gboshko
no, i'm still stuck..i've found another tutorial on augi but when i try to make my own the same plan problem keeps comming back
its really frustrating cuz they make it look so easy in the tutorial...
my bet is there something that i dont set adapatative or vice versa
if you solve the problem please let me know
i'll do the same
gboshko
Message 5 of 19 (523 Views)
10-23-2012 03:55 PM in reply to: Mike686
Hi mike,
Somebody from Augi got back to me. I’ll be uploading a data set at your post tomorrow for him to look at. Hopefully we will have an answer shortly.
George
Employee
NicolasXu
Message 6 of 19 (509 Views)
10-24-2012 12:15 AM in reply to: gboshko
Hi Mike,
Nicolas Xu
Sr. SQA Eng.
gboshko
Message 7 of 19 (499 Views)
10-24-2012 05:17 AM in reply to: Mike686
Thank you Nicolas,
I have been grounding my parts and using line geometry instead of points.
I will give your method a try.
Appreciate,
George.
gboshko
Message 8 of 19 (485 Views)
10-24-2012 03:33 PM in reply to: Mike686
Nicolas,
Problem solved!
Your dataset really helped me out.
In my layout sketch I had one corner constrained to the origin. This is not correct if the intent is to use the i-copy on other work planes.
Thanks again.
Valued Contributor
Mike686
Message 9 of 19 (471 Views)
10-25-2012 07:11 AM in reply to: NicolasXu
Nicolas thanks for the reponse, i will try it
and see if everything work for me
Valued Contributor
Mike686
Message 10 of 19 (446 Views)
10-29-2012 11:02 AM in reply to: Mike686
hi Nicolas, i've use the tips you gave me and it solve a lot of problem
i still have one problem i can seem to correct..
i'm posting the layout part and the assembly
the problem is with the body i did with the sweep command
when insert it with icopy everything work fine
but when i change a dimension in the target assembly, i lost the body (solid 4) in my icopy
the other solid bodies are ok
can you check it out and see if you can find what i've done wrong??
