I have an intermittent issue and was wondering if anyone has had their icon's on the toolbar
get all messed up!
If I reload the assembly it all goes back ok. It only happens on the Manage toolbar, all others work as normal
Any ideas ???
thanks
Mark
Inventor Professional 2013
64-Bit Edition
Build: 176 Release 2013 SP1.1
Graphics Card
Driver Packaging Version 8.773.1.1-110115a-112278C
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1071
Direct3D Version 8.14.10.0779
OpenGL Version 6.14.10.10225
Catalyst™ Control Center Version 2011.0115.2247.40819
Primary Adapter
Graphics Card Manufacturer Powered by ATI
Graphics Chipset ATI FirePro V4800 (FireGL)
Device ID 68C8
Vendor 1002
Subsystem ID 240A
Subsystem Vendor ID 1028
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 012.020.000.004
BIOS Part Number 113-C02005-101
BIOS Date 2010/02/25
Memory Size 1024 MB
Memory Type GDDR5
Core Clock in MHz 775 MHz
Memory Clock in MHz 900 MHz
Total Memory Bandwidth in GByte/s 57.6 GByte/s
Solved by JDMather. Go to Solution.
I had this happen to me during the certification exam (timed), fortunately I knew a quick fix without having to restart the program.
Click this black arrow 3 (or was it 4) times.
Hi JD,
thanks for the quick reply,
I will try Cycling through the Panel Button Icon next time this happens
thanks
Mark
