What does this error mean?
I have an iAssebly that was working fine, and I added a part that was the same throughout all configurations. Now, every other configuration has replaced a component with the wrong ipart configuration. The ipart has the configuration I want to use, and I've found nothing wrong with the part. When I try to set it to the correct ipart in the iAssembly Author table, it allows me to select the configuration I want. I click ok, Inventor thinks, then the error pops up, and the part is in the wrong configuration again.
Inventor 2012
Hi eveylynne,
Could you attach dataset for investigation?
Stanislav
I cannot. I ended up doing a lot of reworking/remodeling and it's functioning this time around.
Thank you just the same!
