Inventor Forum
iAssembly Change Component
5 REPLIES 5
mikebelter
263 Views, 5 Replies
O.K. so I haven't used iAssemblies much and that was a while ago. I created a simple iAssembly and inserted it into another assembly. I cannot change component since it is asking to save to the library, and of course that won't happen. Proxy file is set up in project. Do I have to generate members and insert individual components now? Using Inventor 2009.
Mike
5 REPLIES 5
in reply to: mikebelter
generate members with the project for the iAssembly. This should allow you to generate the members. Then when you use them in other assemblies, the iAssembly members will already be created so it should insert fine.
mikebelter
Josh:
So then the iAssembly members are inserted into the main assembly file, not the iAssembly Factory? Is it an issue that the iAssembly factory I have created resides in a library compared to the Assembly in which I am trying to insert the iAssembly factory?
Mike
when you try to insert an iAssembly factory, it should open the iAssembly table and allow you to select the specific member. If the member does not yet exist (i.e. it appears in the table, but the member hasn't been generated), then the iAssembly will attempt to generate the needed member. I believe this is your problem: the member doesn't exist, so the iAssembly tries to create it, but the iAssembly is in a library so it isn't allowed.
Open the iAssembly, expand the members under the table, RMB on the member you want and Generate. This should now create the member. When you go back to the main assembly, you shouldn't have problems inserting the iAssembly.
mikebelter
Josh:
Perfect, works fine once files are generated.
Thanks for your help.
Mike
Mike,
I posted a ZIP to autodesk.inventor.customer-files. Same Subject line. The
excel file is embedded in the ipt file. Right we have to manually copy the
part number and past it to the part number property. I would like to
automate this if possible.
Rick
wrote in message news:5994483@discussion.autodesk.com...
Mike
