I upgraded to a beautiful, new pc yesterday, and installed/upgraded to IV 2015.
(Windows 7, 64 bit)
I have been working on iassemblies today, editing tables.
I often use the Tab key to navagate.
If I tab around w/o clicking anything, nothing happens.
If I click a box in an a column that dictates exclusion then try Tab, the table closes, and a window for "Create In-Place Component" opens.
If I click any other box then hit tab, the next box becomes selected (as it should).
Shift+tab has the same results.
This happens in migrated and not migrated iassemblies.
I get this to happen rather consistantly.
Solved by bob_holland. Go to Solution.
eveylynne,
This has been brought to Autodesk Development's attention.
Thank you.
Good afternoon,
I was just wondering if this is a low priority issue, or if I might see a solution soon-ish.
Thanks for being awesome!
-Evelyn
Edited by
Discussion_Admin
Hi! We are aware of this issue and we are working on a solution. We will let you know when it is available.
Thanks!
Eveylynne,
I did some test and it appears that this is resolved with Autodesk Inventor 2015 Service Pack 1:
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-in...
Please test this and let me know.
