Inventor Forum
Iam-WPlanes-Make Larger
5 REPLIES 5
122 Views, 5 Replies
Is there a setting that you can change to make origin work planes larger when you open a new iam up? Now they are like an inch by an inch.
5 REPLIES 5
Set component priority to faces, edges or feature and then go to the corners of the workplane and you would be able to see the resize cursor and then you can resize. Thanks.
shekar
I figured that out, but what sets initial size from the start. I would like them to be 6" by 6" or something larger.
Anyone?
R.Corriveau
Resize them in your template and from now on when you start a new assembly they will be bigger.
Thanks Rick.
