Just accidently launched Fusion again.
Waiting, waiting, waiting.....
Sounds like operator error... 😉
have your had any training
Please take a number and wait your turn.
or in your case ...
Please take ANOTHER number.
@mcgyvr wrote:Sounds like operator error... 😉
No Desker was present so I hit my own right mouse button finger with the hammer.
Now bandaged - I'm holding it up in solute to Autodesk, it will be a while till I can make that operator error again.
Someone else try this - open the file here, and launch fushion with RMB on first Loft
http://forums.autodesk.com/t5/Autodesk-Inventor/Fillet-Help/td-p/3107526
hold your RMB finger in the error until Fusion fully loads.
How long did it take.
I just love that it looks like an instant CTD!
20 sec till splash screen
1 min till loaded
10sec till back to IV
Also that they put Edit Form WAY above Edit Feature or Edit Sketch
Which do you use most often?
Which sells more seats??
this is a daily cuss from our guys here... horrific.. automatic control alt delete.. then end process on fusion
With the way I feel about Fusion I hate to say it but it only took mine 11 seconds to open it.
Just about as bad is if I ever do try to use Fusion I hit "Return to Inventor" by mistake when I expect "Finish" to be on the end of the ribbon bar.
@mbenoy wrote:.... only took mine 11 seconds to open it.
Is this by using Edit Form on RMB options or did you open directly with Fusion?
@Anonymous wrote:Is this by using Edit Form on RMB options or did you open directly with Fusion?
Exactly as requested. RMB and Edit Form on first loft.
@mbenoy wrote:
@Anonymous wrote:Is this by using Edit Form on RMB options or did you open directly with Fusion?Exactly as requested. RMB and Edit Form on first loft.
Had you run Fusion this session (since last reboot?
Actually, I'm not sure which feature I accidently hit Edit Form on, all I know is that I had to get up and leave before I put the hammer through my screen.
This is going to cause real headaches in classroom instruction or imagine you boss comes up and asks you a question and just as you start to make a change - essentially a lock-up while Fusion loads. Oh yeah, you know how to run this program..... ...good luck supporting Inventor next meeting the SWx fans start pushing.
Yes, I had run Fusion a few hours ago. I had opened a SAT file to look at and then closed it.
@mbenoy wrote:Yes, I had run Fusion a few hours ago.
My guess is that if you rebooted your computer (not asking you to go this far) it would load much much slower launching from Inventor.
@Anonymous wrote:My guess is that if you rebooted your computer (not asking you to go this far) it would load much much slower launching from Inventor.
"I gots to know."
After a reboot and the nearly 2 minute wait for Inventor to start, it took it 40 seconds from RMB/Edit Form on Loft 1 until opened in Fusion.
OK, that's enough Frustration, uh, I mean Fusion to last me for a while.
I'm still waiting on my number to be called to hit Autodesk with a Hammer.
