I would caution trying to tie dimensions to annotations because annotations
are not part of the geometry. If the annotation moves or need to be moved
later, then your reference for that dimension will now be wrong.
Dimensions/annotations should always reference the base feature of the
geometry they are meant to dimension or annotate.
Ken
"MarcoA" wrote in message
news:5220237@discussion.autodesk.com...
il giorno 27/06/2006 17.42 Andrew Faix (Autodesk) ha scritto:
> The REAL problem here is extension line formatting.
Formatting the extension line could be a (good) workaround: I could
continue to attach my extension line to the geometry (lines, centres,
axes), and THEN dragging the end of the line in order to avoid it to
overlap the section line.
I used this technique in other CAD softwares, but I always found it so
imprecise! How much should I drag?
If I could directly attach extension lines to every other line in the
view (section lines, in this case), it would be the best.
Just My 2 Cents, of course!
I wonder why it's not an implemented feature, and why it is so much
more difficult than attach the extension line to every other line in
the view... You know, I'm a very curious guy! (-;
Thanks.
M.
