OK, I think I understand. So to clarify, you're not necessarily wanting to
dimension the actual section line, you want to dimension to a feature (hole
or other circular edge) that the section line is constrained to, and you
don't want the extension line running all the way through the section line.
In essence, you want that dim gap, correct?
Andrew Faix
Product Designer - Inventor Drawing Manager
"MarcoA" wrote in message
news:5219968@discussion.autodesk.com...
il giorno 27/06/2006 14.49 Andrew Faix (Autodesk) ha scritto:
> Geez, until I chimed in the assumption was that you couldn't do it at all,
> now that I show how to do it there's complaints that it's too difficult?
> OK, I don't disagree, but its bigger than just being able to dimension to
> the section line....really.
> Is it necessary to change the reference attribute? That's entirely
> depends
> on the situation and is up to the individual user. I just wanted to show
> that you could.
Thank you!
It's not exactly what I was wishing, but... I'm happy to see that it
is actually possible.
What I wish is to be able to manage section lines the same as I do
with axes or centers (just in dimensioning step). It has nothing to do
with my laziness or with the number of mouse clicks: it is because
adding dimensions to a view is a different (and following) step than
editing sections. In an ideal work-flow, it's something like "adding a
new layer" over the "layer" of views and sections, and over the
"layer" of centers and axis.
The question rose when trying to add a dimension between two holes
centers: one of them had a section line passing throught, so that a
reference line overlapped the section line (I always try to avoid
lines to overlap, if possible). The solution would be to attach the
dimension to the section line. And so it is.
My new wish is that... the process will be as simple as "normal"
dimensioning, and... as simple as it is in other CAD softwares... ((-;
Thank you very much!
M.
