Inventor Forum
I WANT TO KNOW HOW TO GIVE THE HEIGHT FOR ARC IN ACAD INVENTOR
4 REPLIES 4
viveksriramr
463 Views, 4 Replies
4 REPLIES 4
JDMather
in reply to: viveksriramr
This question has been answered here within the past 5 days.
A search should turn up the solution.
What version of Inventor are you using?  (solution depends answer to this question)
Actually I read this as arc length.
But if you really need arc height - simply create construction line and dimension.
If you attach your ipt file here it might be clearer what you need to solve the problem.
viveksriramr
The part is attached, i want to take the overall height of the tile.
viveksriramr
we are using Acad Inventor 2013.
blair
For the record it's Autodesk Inventor, not sure what Acad is.
You could dimension from the edge to the mid-point of the arc to get the height (crown) of the arc.Capture.JPG
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
