I WANT TO KNOW HOW TO GIVE THE HEIGHT FOR ARC IN ACAD INVENTOR
Solved by viveksriramr. Go to Solution.
This question has been answered here within the past 5 days.
A search should turn up the solution.
What version of Inventor are you using? (solution depends answer to this question)
Actually I read this as arc length.
But if you really need arc height - simply create construction line and dimension.
If you attach your ipt file here it might be clearer what you need to solve the problem.
The part is attached, i want to take the overall height of the tile.
For the record it's Autodesk Inventor, not sure what Acad is.
You could dimension from the edge to the mid-point of the arc to get the height (crown) of the arc.
