Inventor Forum
I need some help writing an equation in Parameters
5 REPLIES 5
TRYoung71
755 Views, 5 Replies
I need to put the following into equation form to plug into a User Parameter:
if d91 falls in the range of 4" to 11"
then d92 = d91 + 2"
else d92 = 7.5"
For some reason, I can't seem to wrap my head around this one.
Thanks in advance!
Windows 7 Pro, SP1
Inventor 2012 SP1
Due to the nature of our business, I am not permitted to attach any files showing models or .idw environments of any actual work-related components.
5 REPLIES 5
japike
in reply to: TRYoung71
This is the perfect senerio to start leaning iLogic. Check out the help files.
Peace,
Jeff
Inventor 2022
TRYoung71
in reply to: japike
Thanks, Jeff!  I'm still learning Inventor, and had not used iLogic yet.  I appreciate the nudge in that direction!
Windows 7 Pro, SP1
Inventor 2012 SP1
cwhetten
iLogic is going to be the way to go.  This is a simple rule to create.  On your manage tab, click the "Add Rule" command, and give your rule a name (whatever you would like).
Type your rule to look like so, or copy and paste:
If d91 >= 4 And d91 <= 11 Then
	d92 = d91 + 2
Else
	d92 = 7.5
End If
iLogicVb.UpdateWhenDone = True
This will give you what you seek.
iLogic is a very powerful tool, and it is definitely worth investing some time to learn.
Edit:  It would also be good to get into the habit of naming your critical parameters so that they are easier to find and use in iLogic.
TRYoung71
in reply to: cwhetten
Yep.  That's what I came up with, after Jeff nudged me in the iLogic direction.  I appreciate your time, too.
Windows 7 Pro, SP1
Inventor 2012 SP1
nmunro
iLogic is a great way to go. A solution for the parameter only approach (Done with just user parameters)
https://c3mcad.com
