I need to put the following into equation form to plug into a User Parameter:
if d91 falls in the range of 4" to 11"
then d92 = d91 + 2"
else d92 = 7.5"
For some reason, I can't seem to wrap my head around this one.
Thanks in advance!
Solved by cwhetten. Go to Solution.
Thanks, Jeff! I'm still learning Inventor, and had not used iLogic yet. I appreciate the nudge in that direction!
iLogic is going to be the way to go. This is a simple rule to create. On your manage tab, click the "Add Rule" command, and give your rule a name (whatever you would like).
Type your rule to look like so, or copy and paste:
If d91 >= 4 And d91 <= 11 Then d92 = d91 + 2 Else d92 = 7.5 End If iLogicVb.UpdateWhenDone = True
This will give you what you seek.
iLogic is a very powerful tool, and it is definitely worth investing some time to learn.
Edit: It would also be good to get into the habit of naming your critical parameters so that they are easier to find and use in iLogic.
iLogic is a great way to go. A solution for the parameter only approach (Done with just user parameters)
