I want to make an angular dimension, but just show me the lines without number or text, but I can't, any body knows how to do it.
Solved by mcgyvr. Go to Solution.
Hi Jose,
Welcome to the forum. Are you sketch or drawing environment?
OK,
Can you post an image of the lines you want to dimension? If you have windows 7 go to start / all programs / accessories / snipping tool. That will help you capture parts of the screen so you can post it here.
Can we see some images, the file? without these we can't help you.
I would just place the dimension.. edit it.. check the "hide dimension value" button and you will have to add something.. be it a period or asterisk or something that you can put there so it doesn't show <text>
You will just have to come up with something you can put there thats acceptable.. but you must have something.
like this..
