Inventor Forum
I need help - Knife Blade
9 REPLIES 9
Message 1 of 10
1733 Views, 9 Replies
ok so im making a knife and i have the sketch done. i etruded it to 3mm i then put the edge on it on all the sides except for the pointed part it says that the comand is to difficult to do. any help would be greatly welcomed.
Edited by
Discussion_Admin
9 REPLIES 9
Message 2 of 10
mpatchus
You could create the shape, then use the chamfer tool to apply the desired edges.
Something like this part attached.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 10
EScales
What about this?  I modified your part.
Message 4 of 10
JDMather
First thing I notice is that your sketch is not fully constrained.
Second thing I notice is you have a bunch of repeated dimensions that are not needed. (see attached)Repeated Dimensions.png
Let's start this thing over again from scratch.
Sketch a single line horizontally from the origin over to the right and dimension it 173.015
Attach the file here.
Message 5 of 10
EScales
in reply to: JDMather
I noticed the same thing, but didn't want to get into teaching a basic Inventor class.
Message 6 of 10
JDMather
in reply to: EScales
First post by OP - we should get them doing the basic stuff right before they develop bad habits.
Message 7 of 10
mpatchus
I couldn't open his part since it is done in 2013.
Wasn't aware that the sketch geometry was unconstrained.  Man Sad
Way to straighten him out JD!
Inventor 2025 Beta
Message 8 of 10
hey thanks how did you do this so i know for future sketches?
Message 9 of 10
EScales
Take a look in the browser of the part.  I added Sweep1, Sweep2 and Mirror1, before your Chamfers.  You can see where I created a sketch at the end of the straight portion and swept the triangular portion around the curve to the tip.  I did that twice and then mirrored both of those to the other side.
Message 10 of 10
in reply to: mpatchus
The part attached is mine, but if you look the point it wont come together Jacob Hawk
