Inventor General Discussion
Active Member
0 Kudos
Post 1 of 10
I need help - Knife Blade
784 Views, 9 Replies
01-10-2013 08:27 AM
ok so im making a knife and i have the sketch done. i etruded it to 3mm i then put the edge on it on all the sides except for the pointed part it says that the comand is to difficult to do. any help would be greatly welcomed.
Edited by
Discussion_Admin
What about this?  I modified your part.
Distinguished Mentor
201 Kudos
Post 2 of 10
Re: I need help.
01-10-2013 08:49 AM in reply to: jacob.hawk.fcp
You could create the shape, then use the chamfer tool to apply the desired edges.
Something like this part attached.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Valued Contributor
279 Kudos
Post 3 of 10
Re: I need help.
01-10-2013 08:52 AM in reply to: jacob.hawk.fcp
Eric
Please select "Accept as Solution" if this answers your question.
2,120 Kudos
Post 4 of 10
Re: I need help.
01-10-2013 08:55 AM in reply to: jacob.hawk.fcp
First thing I notice is that your sketch is not fully constrained.
Second thing I notice is you have a bunch of repeated dimensions that are not needed. (see attached)Repeated Dimensions.png
Let's start this thing over again from scratch.
Sketch a single line horizontally from the origin over to the right and dimension it 173.015
Attach the file here.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
279 Kudos
Post 5 of 10
Re: I need help.
01-10-2013 08:58 AM in reply to: JDMather
I noticed the same thing, but didn't want to get into teaching a basic Inventor class.
Eric
2,120 Kudos
Post 6 of 10
Re: I need help.
01-10-2013 09:01 AM in reply to: EScales
First post by OP - we should get them doing the basic stuff right before they develop bad habits.
201 Kudos
Post 7 of 10
Re: I need help.
01-10-2013 09:10 AM in reply to: JDMather
I couldn't open his part since it is done in 2013.
Wasn't aware that the sketch geometry was unconstrained.  :mansad:
Way to straighten him out JD!
Mike Patchus
Active Member
0 Kudos
Post 8 of 10
Re: I need help.
01-10-2013 12:23 PM in reply to: EScales
hey thanks how did you do this so i know for future sketches?
Valued Contributor
279 Kudos
Post 9 of 10
Re: I need help.
01-10-2013 12:31 PM in reply to: jacob.hawk.fcp
Take a look in the browser of the part.  I added Sweep1, Sweep2 and Mirror1, before your Chamfers.  You can see where I created a sketch at the end of the straight portion and swept the triangular portion around the curve to the tip.  I did that twice and then mirrored both of those to the other side.
Eric
Active Member
0 Kudos
Post 10 of 10
Re: I need help.
01-15-2013 06:07 PM in reply to: mpatchus
The part attached is mine, but if you look the point it wont come together Jacob Hawk
