Hi guys,
I just went back to a part i was unable to do a while back and im still having some issues. The problems I am having are at the top of this crankrod.
1. By looking at the drawing i can not see how thick the two (I don't know what to call them) "things" are supposed to be, only how far they should be apart (15mm). What am i overlooking?
2. The R5 fillet that joins the bottom cylinder to the top part of the part, how would I do this? Been trying to fix this with no luck.
Attaching my IPT file (i've guessed the thickness here) with my current progress and the drawing I am following.
Thanks in advance.
Solved by JDMather. Go to Solution.
Rusty
Sometimes bringing image into sketch helps.
Thank you both!
From looking at the .ipt file JDMather's sent, it looks like i should just perform a revolve (for the fillet), please corrent me if i'm wrong.
Also, how do you add an image to a sketch? Really good tip for the future 🙂
Here is how I might model the part. (notice that I did not use Loft or create any extra workplanes)
Use the most primitive geometry possible and avoid creating extra workplanes dependent on existing geometry.
Also, you have the drawings for the mating parts to help figure out logical values for missing dimensions.
To place an image in a sketch
start a new sketch
Click on the insert image tool and place desired image.
Add a horizontal constraint to the image box (or dimension angle if image skewed).
Dimension one edge of image box (I recommend long edge).
Sketch line from dimensioned location on the drawing (the longest dimension).
Dimesion this sketched line.
Edit the image box dimension and multiply the dimension by (known dimension/measured dimension).
This will scale your image to correct size.
Locate the image relative to the origin and Fix constraint or dimension to the origin.
If image is a photograph - use only as reference as there will be parallax error.
Also, after inserting the image I right clicked on it in the browser and set Properties for the background as transparent.
