Inventor Forum
i-logi Driving a part parameter from an assy.
5 REPLIES 5
427 Views, 5 Replies
Hi. I have a multi body part that I componented into an assembly. I am trying to get the assembly parameter in this case, "Height" to drive the parameters in the part model. I think I am using the right code but I get an error when I run the rule. See attached,
Thanks.
George
5 REPLIES 5
cwhetten
It seems backward to me to try to drive parameters down from the assembly level when you are using a multi-body modeling approach.  Why not just put your parameter in the base part and drive it up?
You may be running into cyclic dependency issues.
Can you post an example assembly with parts that shows the problem?
Cameron Whetten
Inventor 2014
mrattray
That error doesn't tell us anything. Can you post the files here?
Mike (not Matt) Rattray
in reply to: cwhetten
The reason is because I need to break the parts down so that I can dimension each part independently for a cut list.
I have used this method in the past  but for some reason cannot get it to work right this time.
Thank you.
cwhetten
Cameron Whetten
Inventor 2014
in reply to: mrattray
Thank you.
I'm not sure I'm attaching the file the right way.
