Inventor Forum
I don't suppose
9 REPLIES 9
Message 1 of 10
177 Views, 9 Replies
I don't suppose
Just did a dumb move. I made a iFeature punch. Placed it on a test part, and all looked
fine, so I just deleted the source. (I usually save them but for some reason didn't this
time) Well when I had tested it I was zoomed in to close to see it was bringing with it
a projected line.
I guess I could just ignore the line, it doesn't hurt anything, but it will probably
always bug me. I tried opening the IDE but I didn't see any way to get rid of it.
Don't suppose anyone has any tricks to fix something like that other than do it over?
Kent
Member of the Autodesk Discussion Forum Moderator Program
9 REPLIES 9
Message 2 of 10
Wish I did know a way to do that ... I've tried to modify iFeatures without
the original ipt, but couldn't figure a way either.
~Larry
"Kent Keller" wrote in message
news:8976D2BF125F468D3FA16741E205742D@in.WebX.maYIadrTaRb...
and all looked
reason didn't this
bringing with it
> a projected line.
will probably
rid of it.
do it over?
> Kent
Message 3 of 10
You can open the IDE file, and use the tools in the panel bar to add/reomove
parameters and geometry.:
and all looked
reason didn't this
bringing with it
> a projected line.
will probably
rid of it.
do it over?
> Kent
Message 4 of 10
But that will only add/remove attributes - you can't change the basic definition. Case in point, I pulled the i-features that Sean has zipped on his site for NPT, NPTF, and SAE ports - all fine and dandy (kudos to Mr. Dotson). However, I would have prefered to have the inital ipt included as his spot faces on some i-features are set to .012 and our company std is .030 deep. I can't change this on his i-feature, I could only do it within the original ipt and redefine the i-feature. This is the main reason we now keep the original ipt next to the i-features we make in house - just in case you decide later to change a basic parameter or make it editable.
Kent, I feel your pain, repeatedly.
Message 5 of 10
Anyone needs the ipt files for the Sun cavities,
NPT and SAE iFeatures Charles posted on his site, just email me and I will send
them to you.
~Larry
But
repeatedly.
Message 6 of 10
BTW that's Charles' site...(not mine)
<g>
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
But
repeatedly.
Message 7 of 10
Seems to me I had the same issue with one I created and one I downloaded
from Charles' site. I just went into the sketch the iFeature was placed in
and deleted the offending entity, redefined the iFeature and it was gone
from future inserts. I know I didn't have the ipt they were originally
created from.
Hal Gwin
Mechanical Designer
Xenogen
Message 8 of 10
To late, I already rebuilt it and overwrote the bad one. I will have to play with that
though. I never would have suspected that you could do that.
Kent
"Hal Gwin" wrote in message
news:8054A4DC173C282007FD45C20958064E@in.WebX.maYIadrTaRb...
> created from.
> Hal Gwin
> Mechanical Designer
> Xenogen
Message 9 of 10
No guarantees Kent, I'm scrambling around trying to gather enough gray cells
mixed in with the gray hair to remember what I did to an iFeature 7-8 months
ago.
Hal Gwin
Mechanical Designer
Xenogen
Message 10 of 10
My apologies to both Sean and Charles. And yes, please send me the ipts if/when you get a chance. Thanks.
rstrickland@parker.com
