Is there a way to pull a flat drawing from AutoCAD Mechanical or maybe a DXF into the IDW envirnment?
Solved by Curtis_Waguespack. Go to Solution.
Manage tab.. insert object
Hi matt.johnson35,
I've done this in the past by using the Draft View tool in the IDW.
I hope this helps.
Curtis
Yes, I was able to do what I needed using Draft, thanks. Insert Image worked but I wasn't able to dimension the image.
