Inventor Forum
I don't suppose
3 REPLIES 3
matt_johnson35
206 Views, 3 Replies
I don't suppose
Is there a way to pull a flat drawing from AutoCAD Mechanical or maybe a DXF into the IDW envirnment?
Matt Johnson
CAD Project Development Specialist
Inventor 2014
3 REPLIES 3
mcgyvr
in reply to: matt_johnson35
Manage tab.. insert object
Hi matt.johnson35,
I've done this in the past by using the Draft View tool in the IDW.
I hope this helps.
Curtis
Yes, I was able to do what I needed using Draft, thanks. Insert Image worked but I wasn't able to dimension the image.
Matt Johnson
Inventor 2014
