I don't understand the meaning of the second reference in the hub section in the key generator, from the Design Accelerator. and i cannot select the circular edge around the shaft, in the hub.
I guess you want to create hub groove on the Spur gear2, you need create a hole feature on it, then select the circular edge as 2nd reference.
