Inventor General Discussion
vlad.kuzik.95
Message 1 of 14 (363 Views)
Accepted Solution
I cannot do anything with this problem. Help me please.
363 Views, 13 Replies
07-12-2013 03:04 AM
I was drawing rectangles (they were green) on a wide box (I saw all of them very well) and then I extruded one of them. As result - other rectangles disapeared. When I was trying to solve this(don't remember how), I made terrible mistake. All rectangles appeared, but then they were yellow. So now I cannot do anything with them, even delete. Help!
I learn Inventor without books. I'm Ukrainian. The Ukraine use method "tourns and mistakes".
*Expert Elite*
JDMather
Message 2 of 14 (351 Views)
Re: I cannot do anything with this problem. Help me please.
07-12-2013 03:40 AM in reply to: vlad.kuzik.95
Attach the ipt file here that exhibits this behavior.
Sounds like all you need to do was right  click on the sketch and turn on Visibility.
Sounds like you created a new sketch and Project Geometry.
Have you gone though the Help>Learning Tools>Tutorials and Skillbuilders?
These http://inventortrenches.blogspot.com/p/inventor-tutorials.html
This http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
petereggington
Message 3 of 14 (345 Views)
07-12-2013 03:54 AM in reply to: vlad.kuzik.95
You have created more than one profile and when you have extruded the first the others will have disappeared. Right click on the first sketch in the 'Model Browser' and select 'share sketch'. You can then extrude the other profiles you have created.
Hope this helps!
vlad.kuzik.95
Message 4 of 14 (324 Views)
07-12-2013 04:31 AM in reply to: petereggington
This doesn't help.  But thanks.
vlad.kuzik.95
Message 5 of 14 (321 Views)
07-12-2013 04:43 AM in reply to: JDMather
It doesn't work. I don't see any changes. It's time to read WikiHelp.
*Expert Elite*
cbenner
Message 6 of 14 (318 Views)
07-12-2013 04:45 AM in reply to: vlad.kuzik.95
As mentioned above, please post your part file on here.  One of us will be able to look at it and help you figure out the problem.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
vlad.kuzik.95
Message 7 of 14 (311 Views)
07-12-2013 04:57 AM in reply to: cbenner
*Expert Elite*
karthur1
Message 8 of 14 (298 Views)
07-12-2013 05:17 AM in reply to: vlad.kuzik.95
There are many sketches in this part.  There are several ways to turn off the visibility of the sketches if that is what you are wanting to do.
Tip:
To find the sketch in the browser, right click on an element in chose "Find in Browser".  then right click on the sketch name in the browser and uncheck "Visibility.
You can turn off all sketches in the part from View>Object Visibility.  Uncheck 2D and 3D sketches here.
Post back if you need more help.
Kirk
vlad.kuzik.95
Message 9 of 14 (292 Views)
07-12-2013 05:25 AM in reply to: karthur1
Thanks. But where I can find my rectangles now.
vlad.kuzik.95
Message 10 of 14 (283 Views)
07-12-2013 05:52 AM in reply to: karthur1
When I close this part and open beck, these yellow rectangles apeared again. How can I protect?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
