Inventor General Discussion
Member
santifis
Message 1 of 8 (314 Views)
I can´t see the whole screen
314 Views, 7 Replies
01-08-2013 12:12 PM
Hi to everybody
Well I have tried with different resolutions, but even with the highest one 1366x768 I can´t see all the panels on the Inventor screens. It´s like my screen is to small to show all the windows inventor has.
How can I solve the problem?
I attach an image to show the problem, I can´t see what´s under the "point alignment" option, I can´t see the "accept" nor "cancel" buttons.
I tried to search on google and here in the forum but I couldn´t find anything, I hope not to ask something has already been asked before.
the system requirements say you need at least a 1,280 x 1,024 or higher screen resolution
system requirements are here: http://usa.autodesk.com/autodesk-inventor/system-requirements/
if your resolution is to small not sure if you can do anything about it
Look carefully at your display settings.  Some graphics systems (Nvidia comes to mind) will have settings that allow you to expand your desktop to a larger resolution than the actual screen. The desktop scrolls when your cursor hits the edge of the screen.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
DarrenP
Message 2 of 8 (309 Views)
Re: I can´t see the whole screen
01-08-2013 12:16 PM in reply to: santifis
Member
santifis
Message 3 of 8 (302 Views)
01-08-2013 12:27 PM in reply to: DarrenP
Ups, I didn´t know that, thank you for your reply. At this moment it´s a nightmare but I have a tip to select the buttons I can´t see, I use the tab button several times and click, sometimes I click cancel, sometimes accept it´s like guessing.
Maybe that helps people with the same problem.
-niels-
Message 4 of 8 (274 Views)
01-08-2013 11:27 PM in reply to: santifis
Do a google search on "infinite screen", it's freeware that allows for scrolling a virtually larger desktop.
I haven't tried it myself, but maybe it helps.
Otherwise you can always search for other virtual desktop software.
Using IV2014 Pro SP2 - upd.1, Win7-64bit
*Pro
sbixler
Message 5 of 8 (252 Views)
01-09-2013 04:43 AM in reply to: santifis
Sam B
JDMather
Message 6 of 8 (250 Views)
01-09-2013 04:48 AM in reply to: santifis
santifis wrote:
..., I use the tab button several times and click, sometimes I click cancel, sometimes accept it´s like guessing.
I used to have that problem in classrooms on data projectors that at the time didn't support high resolution.
My solution was to count the number of tabs needed from a particular location and memorize.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Mentor
stephengibson76
Message 7 of 8 (246 Views)
01-09-2013 05:13 AM in reply to: santifis
or use your video settings to rotate the screen, click ok and then rotate it back
Stephen Gibson
View stephen gibson's profile on LinkedIn
Member
santifis
Message 8 of 8 (231 Views)
01-09-2013 07:27 AM in reply to: sbixler
Thank you to everybody.
FInally I solved the problem changing one of the display options, I had medium display 125%, I changed it to default 100% and now I can see everything, I´m very happy. I didn´t even know that I had the 125 option activated.
Before that I tried windowslider, unfortunately the desktop is infinite only in the left to right direction, but nothing changed in the top to bottom  direction, so it didn´t solve the problem.
I didn´t test the option of rotating the screen since it is solved, sorry.
See you in other threads friends!
