I'm having a problem when I place iFeatures that I have created into a new part. The iFeature I created has some dependent features within it (It's basically a counterbored hole from the top side, then a circular pattern of counterbored holes from the underside. So the holes on the underside are automatically included in the iFeature when I select the top hole). Anyway, when I try to place a dependet set of iFeatures like this, I can't specify any rotation. For instance, in the position tab I select the top surface, then input an angle (say 90 degrees), then select the bottom surface, hit finish, and the iFeature places itself at 0 degrees every time. Anybody have any ideas?
