If you are using the version that changes icons, you are significantly
out of date. The current version (and several prior) uses the same icon
in all environments and is significantly better.
Quinn Zander wrote:
>It's an icon in the browser (Feature Panel) that changes with each mode.
>QBZ
>"tomdedrick" wrote in message
>news:16154029.1082842489781.JavaMail.jive@jiveforum2.autodesk.com...
>>I have installed C Bliss' i assembly tools but I can't figure out how
>to access them to use them. I don't see any icons or menu items!
>>Tools | Add-Ins shows AssemblyTools Startup/Loaded.
>>No doubt I am missing the obvious again!
>>TomD
